small finishing touch that was necessary
any problems with the pastel coolant?
Very tidy inside and the colour you chosen and the way you've blended it together it just so nice!
One thing though, how did you change the colour on the front panel?
Wondering cause im gonna buy the trooper soon and I want to change it to white, I personally don't like red as LED.
i had managed to burn something on PCB for the fan control and light control when i was testing 8 corsair SP 120's so i cut all the cable for that long ago...
so i cut out the part of the PCB that didn't interfere with the audio jacks and USB ports and placed some green LED strips in there. pretty simple.
I have the cm storm stryker planning a WC. my question is what did you use to connect the res to the case? I plan on getting the bitspower 150 upgrade kit with there mod top for the d5 pump? Great looking systemby the way love the color scheme.
Why not SLI 780? Or even a 7970ghz Xfire setup instead of 770Sli? Gonna need that 384bit bus and extra Vram. Though you won't need more than 3gb.
Love the rig Benito! It looks incredible.
If you let me know what games you play I can run (assuming I have it) them using my SLI Titans and keep an eye on VRAM usage to give you an idea if they use more than the 3GB of VRAM that a 780 has. I also game at 5760x1080
Cheers,
Ulijin.
great looking rig. slightly jealous
