Hi,
As i've previously killed of components due to heat - Im pretty insistant that this build must be properly cooled. I am purchasing the Fractal Design R2 Case - This case comes with 2 Fans which although make very little noise, don't push too much air. I am planning on putting both these fans at the front, I then intend on having the Noctua NH-U12P SE2 Cooler, Due to the Push-Pull configuration I'll be going for, I wondered if having another NH-U12P fan as the exhast would create an air tunnel, effectively keeping the case and CPU as cool as possible.
I was considering having a 140mm roof fan but I want to keep the PC as quiet as possible, plus the fact it might not actually do much.
With the front fans not pulling in too much air, will the single Noctua NH-U12P be enough for an exhaust?
For reference here's the build I am aiming for.
Thanks.
- Asus ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card
- Intel Core i7 920 D0 Stepping (Socket LGA1366)
- Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard(Socket 1366) DDR3
- OCZ Obsidian 6GB (3x2GB) DDR3 PC3-12800C9 1600Mhz
- Fractal Design Define R2 Midi Tower Case - Black Pearl
- OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply
- Noctua NH-U12P SE2 Dual Fan Quiet CPU Cooler/AM2/AM2+/AM3)
- Western Digital Caviar Black 640GB SATA-II 32MB Cache (For RAID 0)
- LG GH22NS50 22x DVD±RW SATA ReWriter
Thanks.
