Noctua NF-F12 PWM 120mm Focused Flow
Tripp
too many shrooms
i have just ordered a pair of these for my h100i, am just wondering peoples thoughts on them. they will be in a pull config so i wont be able to see them, and there supposed to be very quiet (i hope so as the corsair stock fans seem a lil noisy
Youll need to wire them up direct to your psu dude, you cant connect them direct to the H100i they wont work the same as the stock fans.
Also connecting to your mobo is ghey.
Set them up with a fixed speed, either with or without the fan speed reducer depending how quiet you want them.
ahh cheers for the heads up tom i have some spare fan speed reducers :)
Where did you order them from and how much? Everywhere I find them, they are about £20 per fan.
I am stuck between these or the Corsair SP120 performance edition. Which provides better positive pressure inside cases?
I can get the SP120 perf edition twin pack for £22.
I am after 5 fans. 2 front intake, 1 rear intake and 2 top exhaust for H100
right guys just wondering are there 4pin to molex 7 volt adapters i can but, as the ones i had were for 3pin any advice would be great
thanks
nevermind guys i just modded the cables i had got them running at 7 volts, and my rig is quiet its amazing how much more noise the stock h100i fans make.
you can close this thread now :)
