No usb connection
dixsey
Hi
I have just upgraded my pc and i am now running windows vista home premium.However i can not get the control centre software to open,it keeps saying usb error and immediately shuts down.I have tried plugging the usb cable from the mach IIGT to every usb header on the mobo but nothing works.I put my old dfi mobo back together and plugged the usb cable in and it worked fine on that.If anyone can help i would be very greatfull as i want to increase my fan speeds but cant at the moment.Thanks in advance.
Regards Dixsey.
There are no vista drivers for the Mach units yet as far as I am aware - but uyou should be able to set it up in XP and then reconnect to teh vista unit and maintian the last set of fan speeds you had previously.
Cheers
Mav
Cheers
Mav
Hi
I thought that the fans default to normal speed everytime you reboot the system.I will give it a try anyway and thanks for the help.
Dixsey
Cheers
Mav
Thanks very much mate,that was my first post on this forum and you answered my question very quickly and very correctly.I did what you said and it worked a treat,now when i run my rig the fans are running at the faster speed i set in XP.Excellent site,thanks again.
Regards Dixsey
