NIC Teaming / Rotating NIC's
Phunky
I've been looking into setting up NIC Teaming without extra software for a while now, but i just cant seem to get it going.
If i use WinGate 6 + i can setup a software proxy which will rotate connection requests through both my NICs and helps me double my connection (i have 2 modems)
But i wish to do this myself without a extra software, does anyone have any idea how to do this via Windows XP or even old skool way via cmd ROUTE?
AFAIK there is no way to do this without either using a dual-WAN router or using software such as Wingate.
I just picked up a new dual port NIC last night to run my 2 cable modems in to and will be using Wingate as it's the most highly recommended software for modem binding and load balancing. I have a Buffalo router with DD-WRT that is programmable to have dual WAN ports but it only does simple round-robin load balancing which isn't as technical as I need.
So basically, Wingate FTW.
From what i've read some Intel NIC's allow you to setup rotation, but what i was wanting to really do is to create the ROUTE myself.
All that Wingate does is setup a ROUTE through the MS TCP Loopback Adapter.
Maybe i need Win2k or something, as this can be done in itself as its use in servers...
I could be off track, but are you trying to team two ADSL connections mate, effectively doubling your up/down speeds?
Kinda ;)
I have two cable modems, i know i cant bond the upstream but i can increase the downstream.
WinGate does this fine, but i wish to setup the same thing without the software proxy.
But also, im wanting to look at bonding for a server as well as im hosting a lan next month and wish to make sure our Patch/Fileserver will be able to handle a lot of requests
Yeah for the servers for the lan UNIX will be fine, but for my PC @ Home it needs to be some form of windows.
Looks like i will just have to make do with WinGate :/ its just so bloated with extra crap i dont need.
name='Phunky' said:
Kinda ;)
Ahh right, I've bonded a few ADSL connections in the past but that was using a bootable linux CD designed for that exact task. There's also a Cisco ADSL router that does the same thing (but is muchious $$$$).
Yeah ive seen the Dual WAN routers and the not worth the £££'s
I'll just stick with WinGate it does me for now and i can still hit 2.35MB/s cant wait until May when Virgin up 10mb to 20mb :D will mean i have 2x20mb :D
name='Phunky' said:
Kinda ;)
U can most definitely bond the upstream, it's the same theory as the downstream however. If it's a single connection either direction it's only going to be able to utilize one of the modems capabilities. For me, I torrent a whole helluva lot, and require the additional upstream bandwidth which can be spanned by 400+ concurrent connections (approx. 200 / modem).
