NH-D14 YEA!
Ulkefar
Just installed the great NH-D14 in my system (raven 03, z77, 3770k). I like silence
My question goes will i be able to get a 4,7-4,8 overclock with the low noise adapter on or?`
Do i connect the fans to header CPU, and CPU_OBT? or just use the converter and plug into CPU? Will there be a difference in performance?
Help Appreciated
Depends If you have a good processor, some can be great overclockers and others not so much, In everyday use anything above 4.5 isnt really going to make a difference
see what works for you
get your overclock sorted on normal fans then add the low noise adaptors when your sure its stable. if the temps get to high for your liking then take them back out
all up to you to find a balance between noise and performance
i remember getting an error if i put the two fans like = one on CPU fan and one on CPU opt
kept saying fan error and the one on CPU opt would stop running
beats me but meybey it can help u out somehow
changed it with a H100 for other reasons tho
