Hi, learning to OC from 2.4 to 3.0ghz, but my main concern at the moment is lowering the Temps that are too high relative to others doing same.
Any advise will be apreciated, thanx, nick
Have no case fans & both sides are remooved.
AMI BIOS 0702 update 2008/07/29 Version: 62.92.38.00.05
The screen shot below is after stressing for 1+ hrs at following bios settings:
EDIT:- sorry anable to insert Screenshot needed.
JumperFree Configuration Settings
AI Overclock Tuner
Manual)
CPU Ratio Settings 9
FSB Srap to Northbridge: auto
FSB Frequency : 333
PCI-E Frequency : 100
DRAM Frequency: 667
Dram Command Rate: auto
DRAM Timing Control
Manual )
DRAM Timings: 4,4,4,12
Write Recovery Time: auto
Write to Read Delay: auto
Read to PRE Time: auto
DRAM Static Read Control: auto
Transaction Booster: auto
Relax Level : auto
CPU Volage: 1.2625v
CPU PLL Voltage: auto
FSB Termination Voltage: 1.20v
DRAM Voltage: 1.80v
N Bridge Voltage: 1.25v
S Bridge Voltage: auto
Clock Over-Charging Mode: auto
CPU Spread Spectrum: auto
PCIE Spread Spectrum: auto
Load Line Calibration: auto
CPU GTL Voltage Reference: Disable
N.B GTL Voltage Reference: Disable
CPU Clock Skew: auto
NB Clock Skew: auto
Advance CPU Settings
CPU Ratio Settings: 9
CPU Ratio Control not in my bios only in the book
C1E Suppport: disable
Max CPUID Value Limit: disable
Vanderpool Technology: disable
CPU TM Function: enable
Execute Disable Bit: enable
PECI not in my bios only in the book
Intel Speedstep Tech: disable (note:- this shows only if CPU Ratio Settings is AUTO)
AI Overclock Tuner
FSB Frequency : 333
DRAM Frequency: 667
DRAM Timing Control
Relax Level : auto
CPU Volage: 1.2625v
DRAM Voltage: 1.80v
NB Clock Skew: auto
