Hi Guys
I seem to have got myself in deep trouble, not having the confidence to build a w/c rig from scratch, I decided to buy a ready built one from a company called Vadim.(now in liquidation).After logging a couple of Bios problems it stopped talking to my screen.(it worked fine for 18 months)
I decided to replace the mobo with the same version, but I cannot source one.
So, my problem is twofold:
1. Can you recommend a SLI mobo that will handle my kit, particularly with regard to position of components and external connections, as movement of cabling and water cooling piping is very limited.
2. As I am well past my "Sell by date", my eyes are not as good as they used to be, and its been a good 10 years since Ive pulled a computer apart, does anybody know if there is some sort of club or group in my area (Basingstoke), that could advise/assist when I get myself into serious problem areas.
Thanks for reading a rather long post...:worship:
1 x Lian-Li V2100B Plus Black CASE
1 x LiquoCool Antarctic TX Extreme (CPU+Chipset+2VGA)
1 x Enermax Galaxy Modular 850W PSU
1 x Asus P5N32-E SLI Plus (Nvidia 650i - 1333 FSB Conroe)
1 x Intel Core 2 Duo E6750 Retail (2x2.66GHz 1333FSB 4Mb)
2 x OCZ DDR2-1150 2x1024MB FlexXLC Edition Dual Channel Kit
2 x BFG Nvidia 8800GTX OC 768Mb PCIe HDCP
2 x 150Gb Raptor 10000 16mb E-SATA
1 x 750Gb Barracuda 7200.10 16mb Cache SATA II NCQ
1 x SONY-NEC Optiarc AD-7173A 18x DVDRW
1 x Pioneer 112DBK DVDRW
1 x Creative 7.1 X-FI ExtremeGamer
1 x Windows XP Prof SP2
1 x Windows Vista Ultimate 64 bit
