New upgrade adventure!
Docroc
Hello gents,
So it has been over two years from my original build and I have been itching at upgrading.
• Where are you located? Montreal, Canada
• What is your budget? About $5500 which is pretty much spent but thinking of replacing the CPU cooler.
• Will you need a monitor, keyboard, and/or mouse included in that budget? No
• Shall you be requiring an OS? No
• What will you be using this rig for? Gaming rig
• If gaming, what resolution will you be playing at? Current is 2560 x 1600 but will move to 4K soon
• Will you be overclocking? Yes, but will need some advice on that
• Do you need a full build or will you be reusing some old parts? Reusing SSD drives, case and power supply
Here is my parts list that I have recently purchased for the upgrade
GeForce Titan Xp
Intel Core i7-6900K
NZXT Kraken X42 RL-KRX42-01 140mm All-In-One Water
Asus Motherboard RAMPAGE V EDITION 10
Samsung 960 PRO Series - 512GB PCIe NVMe
Corsair Dominator Platinum Series 64GB (4x16GB) DDR4 Dram 2800MHz
ICY DOCK ToughArmor MB996SP-6SB
Serveraid M5015 512MB Sas/sata Lp Hba 6GBPS
Here is the parts I am reusing
CORSAIR Professional Series Gold AX1200
Silverstone Temjin Series TJ11 Case
So I have two things I wanted to ask advice on:
1. Overclocking the x99 with the 6900K and 2800Mhz ram. Wondering if I should try to overclock past 4.2 with the cooler I have, which brings me to…
2. Dealing with the heat. I really wanted to use a larger radiator but the case in kinda funky with only a single 140mm fan spot close to the CPU. I have no experience running custom water cooling and have used All-in-one kits in the past. Is there any kits that include extra-long tubing? This way I can mount a 240mm or larger radiator kit to the bottom and still reach the CPU.
Case internal
Thanks in advance
1. It depends of how lucky you were with silicon lottery. If your CPU can do high clocks with low voltage you may push it a little more. But with single 120mm rad you would be going deaf on that CPU. And i don't think it can cool it properly.
2. I would recommend Alphacool Eisbaer 240 or Fractal Design Kelvin S24 then replace the tubes with longer ones. They use standard 1/4" fittings. Like Tom did in this video:
https://www.youtube.com/watch?v=AFm7Q5tm7kI
