New RAM in overclocked PC
BbBoS
Hi,
I bought an overclocked bundle from Aria.co.uk recently, and want to add some more RAM to my PC, I was wondering if I bought an identical set to add on, would it affect the overclock at all, or would I be better off getting some other RAM (2 x 4GB) instead, because at the minute 4gb isn't enough.
Spec's are (if relevant)
2600K @ 4.80Ghz
MSI P67-GD65
Mushkin Blackridge 1600Mhz 2x2Gb
Thanks
(sorry if there is another post on this, I thought I posted it earlier, but couldn't see it, so re-posted it)
it may affect it but I doubt it as its prolly not highly oc'd I'd say go for it and see. In most cases filling all the slots can affect the oc. But those are set for stable oc so again I doubt you'll have issues. dont know if ya checked the world record oc but that was done with a single stick of ram for stability and they also disabled 6 threads IMHO not a record at all if you disable 3/4th the processor lol anywho I digress.
said this in the other post as well
easy way to find ur posts or replies is in your profile page click on view my content and you'lll find it
