Phil Stanbridge
Right guys I'm actually seeking some advice for a change!
I am going to be watercooling my system for the time being, which will be as follows:
Asus A8N-SLI Premium
FX57
2GB OCZ VX3200
OCZ PowerStream 600w
XT PE
4 hard disks (two Raptors, two Seagate Barracudas)
2 Plextor opticals
Fan O Matic Pro
I have decided to use a Mountain Mods case as seen below as the chassis for practical reasons and aesthetics. Its a big case with lots of potential and I fancied using something different. I'm not going to be using much in the way of LED lighting however so ignore the blue over-powering effect.
I will watercool the GPU and CPU only at this time with the possibility of watercooling the hard disks at a later date should this project last the initial 4 week trial period I have set
I intend to use a HE120.3 rev 3 with shroud and 3 120mm Papst fans for silent cooling. I'm hoping this would suffice - I hate irritating fan noises, so quieter the better without sacrificing too much cooling potential. Take into account there are 9 blowholes on that monster, that will take some serious cooling. I would like to use Papst fans all round, off the Fan O matic Pro at 7v which should prevent the case from taking off.
I am using the Storm G5 on the CPU and Maze 4 with ramsinks on the GPU. I will be using 1/2 tubing, along with a single AQZ 50Z pump. I'm not sure which res to use in this system either - for absolute good looks a bayres would really finish it off but I've only got 5 optical bays in there, and I have two opticals and a fan controller already. Leaving me with room for a Dual bayres - or should I opt for a Thermotube and mount it somewhere in the case?? Decisions...
FX57
2GB OCZ VX3200
XT PE
2 Plextor opticals
Fan O Matic Pro
