Just got done watching your new review on the 7820x. I'm in the process of building a new PC. I have been going back and forth from Intel or AMD, to what one I should get. I have had Intel for many years. I want to get the best bang for my money and last me many years before another upgrade. So I have a budget but if I need more I can go more.
• Where are you located? USA
• What is your budget? $2000.00 but might be more since I might not get all parts at once.
• Will you need a monitor, keyboard, and/or mouse included in that budget? monitor trying to get the G-sync with 2560x1440 with 1ms
• Shall you be requiring an OS? YES
• What will you be using this rig for? Twitch, Gaming and making YouTube Videos
• If gaming, what resolution will you be playing at?2560x1440
• Will you be overclocking? YES
• Do you need a full build or will you be reusing some old parts?Samsung evo 500gb and Corsair hx850
