hello
im getting myself some new parts but i need some advice how i can improve it
if have already got the PSU and GPU
and i also got the case already
i can only go 30euro above the 959 euro total
Thanks for replying in advance
3- Get an H100i. I know it costs a bit more (About €10,-) but it comes with much better fans and tubing. It's also by Corsair so they'll have you covered with warranty.
Personally, I love my Seidon 240. The pump is silent, and performance is very close to the H100i. I'd keep with the Seidon tbh.
Correct me if i'm wrong but you can also save few bucks by swapping that case out with an Arc Midi R2 which is a lovely case for the price. It also has some great features and is really easy to work with (cable management, dust filters, rad offset on top for running p/p, etc...).
hello
what site is this list from I can try create a list of my own sticking to your budget around the 950 euro mark?
azerty.nl
i also updated the list i went over the budget with 20euro but thats not realy that bad
i changed the RAM to 1866MHz and its on 1.5volts
added an ssd and also changed the board and the SATA
also thanks for all the replies !
how *much* memory is going in this build, forgive me if I missed it but I'm not seeing 8GB or 16GB ?
its still a 2x4gb and i already said in first post that i have the GPU already
i just gave the full list so i know for sure it al goes together
