New Motherboard
NugentS
I am looking for a new motherboard for one of my computers with a perhaps slightly unusual spec.
Its not for overclocking (I know heresy) but will be used completely standard. No games either so graphics are not important
The minimum spec as follows:
Intel Quad Core (not the new ones)
4-8 GB Memory capable
1 PCI slot for graphics (or on board would be fine)
Lots and lots of PCIe slots for things like RAID cards and network cards.
N.B. PCIe 1x is useless - the slots need to be 4x minimum with at least 1 8x on the board
As an alternative (if such a thing exists) I would use as PCI-X board with at least 2 * PCIe 4x as well (and lots and lots of PCI-X slots)
Any ideas?
Sean
Preferably
Take a look at the P5Q Range by ASUS, there's something for everyone there and they're pretty solid boards.
did you really mean a PCI slot for gfx or did you mean PCI-E?
also, PCI-E x1 slots aren't useless - there are sound cards, wifi cards, TV cards etc. in that format.
Does sound like you need a P45, X38/X48 or nVidia 780i/790i type of mobo though.
Budget?
I like the EVGA 750i FTW they seem to have the reqs you need, or you could try any other board by asus as they have a good range of P5Q :D as -VK- said
I really meant PCI for graphics - this is to run Linux in text mode only - so any PCIe x16 slots will run other boards - not graphics in x4 or x8 modes
And for my purposes PCIe 1x are in fact useless (almost) - I want x4 minimum (Intel dual NICs are x4) - and I am looking for lots of NICs to run 802.1AD
At the moment I have an Asus board running 2 * 3Ware RAID cards, 1 * dual NIC and a single NIC that might be x1 or might be PCI (I am not up to taking it out of its cubby hole to find out at the moment). Thats 1 * x8 and 1 * x4 for the RAID, a x4 for the NIC and I am reasonably sure a x1 for the single NIC.
Ideally I would like 1 * x8, 3 * x4, a PCI and as many x1's (faster=better) as are available (for extra NICs). I looked at the P5Q range and didn't spot anything better than what I have already (and mostly worse)
Budget £300 (up to) - so any consumer board would be considered
Sean
this one has it all hasnt it? I must of been mistaken.. what proccessor and memory do you have to help me find one in more detail
I have an Intel Quad Core2Duo processor - can't remember which version - but not the newest ones.
DDR2 memory - 8*2GB modules
I could use PCI-X as long as there are two PCIe (8x, 4x) slots as well for the RAID boards
Sean
Hello! :)
I'm looking for a Massive upgrade on my current system and I'm not too sure which motherboard to buy. My main criteria would be DDR3 (2000MHz ) support + reasonable 'overclockability' ...
What would YOU recommend???
P.S Just like to say Thanks for this website - it's really informative ,keep up the good work !!! ;)
