Hi,
I received a new motherboard to replace my old one (as I stupidly bent some pins when cleaning old thermal paste) however I'm not sure if this motherboard is DOA or my PSU has packed in.
I'm getting the problem that the computer will not switch on, no fans spin or lights nothing happens, however there have been a few moments where it seems to be working ok and even it was able to boot into Windows 10 desktop!
If I plug the PSU back into my old motherboard with just a case fan, then this switches on ok (although the PSU makes some clicking noises as if it's going on and off, maybe because there is no CPU)... If then reconnect the PSU back to the new motherboard it starts working again! (no constantly clicking) OR at least until I plug in the graphics card, then nothing switches on again... If I take the graphics card and everything back out and just have the CPU fan connected then the new motherboard will not respond until I seemingly re-attach the motherboard power cable...
I've been having problems recently where my old system would just randomly shutoff with the fans running at 100%, I thought this might be due to overheating but it will happen when I'm just web-browsing or playing games... It might shutdown after 10mins of browsing or after hours of playing games... So this doesn't seems to be a overheating problem so this point to the PSU maybe cutting out momentarily but the fans stay on?? My old cpu fan was the intel stock one which really needs a dusting so I have replaced it with a gigantic twin 135mm fan (which was getting around 27 degrees idle, on the one time the new motherboard booted)
System Setup:
CPU: 4770K
CPU Fan: Be Quiet Dark Rock TF
PSU Corsair AX760
New motherboard: Gigabyte Z97P-D3
Gfx Card: Palit Nvidia 1070 Dual Fan
Ram: Crucial Balistix 8GB*2
OS: Windows 10
I have uploaded some videos to see what everyone thinks might be wrong;
New motherboard doesn't power on, only cpu fan connected
https://www.youtube.com/watch?v=t73LvX1A_pI
Old motherboard powers case fan
https://www.youtube.com/watch?v=lV1zJyNUwxg
New motherboard seemingly working again after being reconnected
https://www.youtube.com/watch?v=dtnsiCYDnRw
New motherboard stops working again with gfx card
https://www.youtube.com/watch?v=vyPrOW04nvg
Note: Removing gfx card does not fix it.
System Setup:
CPU: 4770K
PSU Corsair AX760
OS: Windows 10
