Hi,
I finally got my hands on a TJ07 and can now get some use out of all the WC stuff I've hoarded while waiting for a TJ07. But since I ended up getting an inverted ATX TJ07 with a lightbox I pretty much have to plan my loop all over again and would appreciate some second opinions. I will be cooling the CPU and one GPU (motheboard is an Asus p8z77 pro)
The WC components I've allready got:
Rad: 480mm going in the basement of the case
Res: Phobya balancer 150 (might swap for longer tube)
Pump: D5 with top
I have a couple things im not really sure how im going to do. How should I run the tubing from the GPU to the reservoir? Should I add a 240 rad in the front or 360 in the roof? How should I do the airflow in the top compartment since the tripple 120mm spacein the roof is my only place for fans? I am also not really sure how I should run the tubing through the lightbox, I could place the reservoir against the lightbox so the only tube I would have to worry about is the one from the center hole to he CPU?
I have two pictures that might make it easier to visualize how the tubing runs can be done.
Pump: D5 with top
