New Lian Li A70b setup.
joner
My new case setup (Lian Li A70b).
With black side window,
I placed some probes for thermal readings on the ram, air into rad and hd area to make use of the Scythe Kama front bay controller,
Im really happy with the results . It turned out really neat and tidy . Its a great case for cable routing.
I used heat shrink on all the wires in view on the psu blocks and mobo switches . I also used bbraided cable sleeving on the pump and fan wires.
Ohh ps, I also have 4 sticks of ram back in.
Ohhx2 ps, It was brought to my attention that I have the cpu block hoses connected wrong. This is because I swithched out my D5 pump for a ddc and forgot to change the flow direction . Its sorted now,
Na ,Its murdered by me :).
I just used heat shrink on each seperate wire so I could have more flexability at the plug point . I tried sleeving but found it to be stiff and not very good for getting the tight bend I needed. I also left the part of the wire just before the main cable sleeve bare so for future referance I have easy view of the wire colour's.
very nice. I may have to do the same...just allows that little bit more flexibility. Im liking the final look....cheap to do too..
I was going to spray the case but decided to just do the mobo tray in matt black pvc contact . Atleast this way the mod is revearsable and very easy to do. I got the lazer cuts done in the case for £30 so its been an all round cheap job that turned out very simple and clean looking ,just what I wanted.
