new desk needed
blaindev
Hi folks, just wanted an opinion or two, as im looking to invest in a new PC desk soon, ive a budget of around 150-200 to play around with, and was going to consider a corner unit (corner being the mid section only, with two long desks coming off it) along the lines of this kind of design:
will also be going black on the desk, dont mind if its a plain matte black finish or a gloss either, as long as its black!!! if you can recommend one within that budget (UK only, not shipping from the US) that is good enough, i may even consider painting it myself if it looks good, but if its already finished in black, that would be best!
any help appreciated!
You should build it yourself, that way you can make it fit any wall and have it at a height that suits you.
I would except i couldn't nail together 2 short planks, I am literally that bad at handcrafting something, ill put it into perspective for you all, my art teacher in school actually told me to not come back, there was no point to me attending as I was that bad at drawing and painting! So it leaves me the idiotproof option!
building your own desk is the best feeling and getting to show others what u did. Maybe some you know can help you build one
Get that one, its looks good and even better in black I imagine. Honestly, your desk will become pretty invisible once you get everything setup on it like you want. I'm not handy either, my desk is a black $30 folding table from WalMart.
White desks are the perfect enhancement to any office, den or other space. the color white can help create the sense of greater space. As a general rule, white desks will appear less cluttered due to them seeming larger. Try strewing 30 or 40 sheets of printed material over a wood grain work surface. The white pages with black print combine with the dark brown color to create a chaotic collage.
A white computer desk is the best choice for you if you are all about style. You can add a great deal to the visual appeal of your room with a this desk. A White Desk Chair is becoming increasingly popular in offices as employers are keen to experiment different visually appealing themes to office.
You should try to make it yourself to proof to yourself that you can do, what people told you that you couldn't.
I did that and it helped on my selfesteem
