RX8's are nice but a bit expensive for me considering I don't even drive to work and pay a mortgage
Well this is a 2006 model and only has 5000 miles on it for 15,000. THat is extremely cheap (I talked the guy down) cause normaly a used one would cost about double that amount.
Whats gonna cost me an arm and a leg is the parts im going to put in it. Unlike Mr Kemp here i AM going to race on street and track.
Street Ported 20B 3 Rotor Engine
Innovative GTB 76 dual ball bearing turbocharger
2 mm. Kirbee Apex Seals
Custom Exhaust Manifold
Fluidyne Aluminum Radiator
spearco Intercooler
Tial 50 mm. Blowoff valve
Turbonetics waste gate
Modified 6 Speed tranny
Steel drive shaft
Custon harden steel 52 mm.rear haft shaft
Exedy Dual disc clutch
E Boost boost controller
2 In line Bosh 044 fuel pumps
Heavy Duty Oil coolers
3.90 rearend gear
Microtech EMS lt-12s
6 MSD blaster coils 8106
Custom 3.5 Exhaust system
Aereomotive Fuel regulator
Aereomotive Electronic Fuel Pump Speed Controller
3 1000 cc Primaries Fuel Injectors
3 1660 cc Secundary Fuel Injectors
Custom Fuel Rails
The results of this combination = 657 RWHP @ 9600 RPM @ 14 PSI Boost
Give or take some HP my car should come out around there if done just like my friends. Custom parts of course will be different so that result will be different. But that will give you an idea of what ill be pushing. The 20B should be my most exspensive part considering i think i have to import it
And i have no "friends" that can do this. Im to lazy to just buy a used one and redo it with a friend. Idk, ill see what happens when the time comes.
