The_Governour
First of all I want to say hi - new member all the way from sunny Mallorca - Spain..
SO - finaly I have decided to change case from my HAF XM to the NZXT H440.
I will be using my RS360 rad at the top with push (push/pull dont seem to fit) a RX120 at the back in push/pull - I also have another EX240 but I will leave this one out - and now to the dilemma....
I would like to buy a XTX 360 from EK and place it at the front with push/pull BUT... I am not sure if I will be able to fit my HD anywhere - anyone know or has any experience of this?
I will be using the 2 SSD mounts under the motherboard but I only have 120´s so I need my WD HD for storage.... but with the XTX360 in the front then I lose all of the HD bays...
Also my second question is Fans... Now I have Corsair SP Quiet in push but I want optimal performace/price ratio for this new build.
Here I have the possibility to get:
Noctua NF-F12 for 17.95 Euros - if I were to use these then would it be a good idea to use them on the XTX360 in PUSH and the stock fans in Pull??
CorsairSP Quiet pack of 2 for 20.95 Euros - I have so far 3 of these from my old build.
I can also get the SCYTHE GENTLE TYPHOON 1450 for 14 Euros.
These are my options - what are your opinions? I would need fans for PUSH for the XTX360 and push/pull for the RX120 and maybe push only (if I dont use my older CorsairSP) for the RS360.
I want the performance but also the quietness (I have the stock XSPC fans and when they rev up to 1600rpm then they are loud) and finally Price ratio.
SO? Any help on these 2 subjects?
