mighty_moll
Overclocked my Q6600 go stepping today and noticed that every now and then speedfan is giving negative temperature readings for the CPU and system. The lastest gives CPU -30 and system -40 (fluctuates a bit).
I tried rebooting and it still gave these readings - so i left the pc off for half an hour and now its back to normal. The CPU sits at 37 to 38 C idle and 50 c at 100% load running the 64 bit prime 95 app. The system temp rarely moves 1 degree either side of 35 C.
Is it normal to get these negative readings once in a while (especially after 100% load for a few hours) or do i have a problem that needs addressing?
Thanks for any help!
