hi,
Recently, I have built my PC, for general purpose usage and some games of course. The specification are the following:
CPU - Intel Core i5-4670K 3.40-3.80GHz (Quad Core) Haswell
MOBO - Asus Z87 Pro
MEMORY - Two Kingston HyperX black 8gb 8gbx1 DDR3 1333 CL10 (Total 16 GB)
PSU - Seasonic G-550 Gold Modular Power Supply (550W)
CASING - Cooler Master STORM SCOUT 2
I'm planning to buy a graphics card. Probably GTX760 and also planning to use Corsair Hi100. I'm also curious about the Overclocking and water cooling. Maybe in the near future.
Few questions and need your advice.
1. Is my PSU is enough to handle the load. Especially when I add the GPU?? And is it enough if I overclock the CPU and GPU in the future?
2. Because I planning to custom water cool the unit using EK Kit or XSPC Kit in the future. Is it ok I will buy now a Corsair Hi100? Can I use/recycle the radiator with EK Kit or XSPC Kit?
3. Is my case can handle the hardware?? Do you think it's a small case??
4. If GTX760 GPU still not available here in the Philippines and I really wanted to get a GPU, is GeForce GTX 650 Ti Boost 2 GB ok?? What brand/manufacture can you suggest?
Please advice. Thanks..
MOBO - Asus Z87 Pro
