Need Some Help With Logitech Rebate....
mVp24
Well so last night, at 11:40PM on 7/30/07 PST I ordered my G15 keyboard. I ordered it from ANTOnline with a $25 MiR that had to be purchased by 7/30. Problem is, ANT uses Eastern Standard Time for their invoices so it shows I ordered it on 7/31/07 at 2:40 AM. Do you guys think I can highlight my address and send a note in to Logitech when I send my rebate or something?
Thanks for suggestions :S
I already called them 7 times in the last 45 minutes.
I would think it depends on the terms of the offer. If you can find them, take a look to see if it says the offer closes at a time EST, if not then they may honour the sale.
You could ask ANTonline if they will contact Logitech on your behalf.
I would say ur out of luck. I find it hard to believe any Rebate Co. would change its rules to help anyone out.
Couldn't hurt to give it a try.
It doesn't say anything about offer ending EST :( I talked to one Logitech rep and he said just put in a note highlighting my address and telling them in a note what happened. Another rep said they wouldn't think anything could happen. Another rep said that they're not sure right now. The ANTOnline rep said just put a note in too.
Lol :(
