OK guys, what I want to do is take my old gaming rig (don't worry I have a much nicer new one now) and turn it into an office PC. So I want to keep most of the old hardware, but put the PC in a much smaller, quieter case and update the software. Sound like a good idea?
The PC at the moment:
- Intel Core 2 Quad Q9550 @ 2.83 GHz
- 4GB of DDR2 RAM
- Some Asus ROG Motherboard, standard ATX size
- 2x Nvidia 9600GT SLI I think they are 1.5 GB each
- 700W PSU
- All in a Coolermaster Cosmos case
So as you can see it's a quite dated gaming PC which uses a ton of power and makes loads of noise which I now don't use for gaming anymore.
Can anyone recommend me (for about £200 maximum):
- A small and quiet case for this PC
- A new (preferably passive) graphics card, nothing fancy I was thinking this
- A good hard drive (about 500GB should be fine)
- Much lower wattage efficient power supply
I intend to keep the motherboard, processor and RAM, but ditch the 9600 GT's, old hard drive and PSU. The case is in really good nick, so I'll probably eBay it.
Thanks so much for any help
Merry chirstmas
- 4GB of DDR2 RAM
- 700W PSU
Merry chirstmas
