Hi guys,
I'm looking for some advice for liquid cooling for my new components down there. So my initial thought was to just buy a set from EK and use that, but it occured to me, that those may not be designed to drive 1 4770k, 2 GPUs and 2 240mm rads. I'd like to add that I have no experience with watercooling at all and that I will not build the loop immediatly, but rather in a couple of weeks or even months.
Here's some facts that may help you, help me: The PC Parts are those in my Signature, except for the Air 540, I am still unsure about that and am deciding between that and the 750D.
Then the color-scheme of the build will be black and white, I don't plan on doing any color accents, so I'm going to use either white tubing or white coolant. I am leaning toward white tubing at the moment. If I go for the Air 540, bay res is not an option, because the bays are mounted vertically, not horizontally.
Personally I would prefer to use matte black compression fittings, but I personally don't know any company who manufactures those, so I'd appreciate some help here
I don't know how much room there is inside the case (as I don't have it yet) but I'd like to run the loop with Push/Pull fan config, so I am looking in the direction of thinner radiators, if only push or only pull with a thick rad gets better results, please notify me
What I am most interested in is a pump. I don't know how I would measure how powerful the pump would need to be to power the loop I have in mind and I hope that your experience can help me out there!
Thanks for helping!
PS: I will overclock every component as far as the silicon allows it, so the heat buildup might be quite extensive.
Thanks for helping!
