Remmy
I have Asus Z87PRO and I have no idea I will fit this radiator + push pull config.
The MOSFET heatsink on this board IS higher up on the board than my MOSFET heatsink is but only by a few mm (relative to the top of the board). The fans on the bottom of my radiator go down below the top line of the motherboard by almost 5mm, but still keeping clear of my heatsink by a comfortable amount, so with this one in the image it may be a very snug fit, or it may be slightly too high up :/ Don't worry about it now though, as I see you've ordered it already, just wait and see when it arrives. If not, just do what modding is for, improvise!
Also, I just saw you were wondering about getting a fan on the right most slot above the ODD bays.
Again, I have one there without any modification/removal to the drive bays and it fits fine. It DOES render the top slot partially unusable. I say partially because you couldn't get an optical drive in there, but I do have my fan controller in the top slot (but I had to saw off most of the plastic on the back of the controller so it would fit)
Finally, a suggestion: When installing the top radiator, it may be easier to remove the whole roof section and install the radiator/fans, install the motherboard, then replace the roof. This is what I did and it made fitting it easier. Tom shows this in his Switch 810 review if I recall correctly.
