Hi people im planning to build my first water cooling system into my Antec300 case but as this is the first time ive ever water cooled a pc i dont know what parts to get. I understand that i can just buy a water cooling kit but i would rather custom build my own single loop as feedback from different companies suggest that i may have to externally mount the radiators on the kits in order for them to fit.
Im planning a single loop to the Cpu only, I have a 2x 120mm fan mounts clear on my case and have removed the top 140mm fan just in case the radiator has to be top mounted. Im planning to buy a 120mm radiator as i thought this will be ok to cool the cpu only, but after that im stuck on parts to get to complete the kit.
Im planning to spend around 80-100 mark for the full loop and want to have anti kink coils, apart from that im open to suggestions.
Does anyone recommend any good parts that are cheep but are enough to cool a dual core E1200 running at 2.87GHz?
All help will be appreciated
Stevej696
Stevej696
