Hey this is my first post here and was wondering if I can get some help.
[font=Verdana, Arial, sans-serif, Helvetica]I just got my white NZXT Switch 810 and I want to do my first liquid cooled loop in it.
i have done a lot of research and am pretty confident in what I am doing... I just need a little help with a couple of the liquid cooling components.
Here is the system:
cpu: i7 3570k
gpu: GIGABYTE GV-N670OC-2GD (a gtx 670 with the gtx 680 pcb... so i can use the gtx 680 water block because the gtx 670 is just too small and funny looking)
case: white NZXT switch 810
motherboard: Asus p8z77-v Deluxe
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (Model F3-17000CL9D-8GBXM)
ssd: Crucial c300 128gb (planning on upgrading)
HDD: WD black 750gb
psu: corsair ax750
Now for the water cooling parts:
1. I need help choosing rads... I want a 420mm (3x140mm) in the top with a thickness of at least 50mm (I read that the switch 810 has 15mm spacing for the screws and that one of the only rads that support this is the black ice rad, and that most 420mm rads have 20mm so i need to know if this is true and if so then I need a rad that has 15mm spacing)
2. for the bottom rad idk if i should just go for a 240mm rad or 280mm. I heard that some get problems with the 280mm and require modding.
3. at first i am not planning on doing push/pull (but i will be using high quality fans) (i am not too anal about noise unless it is way over the top)... i want to know if it's really worth going for push pull.
4. for the cpu block it's either the new plexy Ek block or the appogee HD (white)... opinions please.
I am hoping you guys can help thanx
