Trying to build my first computer from scratch, and want it watercooled. Im so tired of the airplane i have at home now (read dell computer)
I was thinking of a ABIT IN9 32X-MAX WiFi, nForce-680i SLI, Socket-775 mainboard and a Intel Core 2 Duo E6600 2.4GHz prosessor.
Figured i would use my old ATI x1950xt 512 mb card untill ati release their x2900 series (which is soon)
Im a total noob when it comes to watercooling, but picked out some components:
http://www.microplex.no/product.aspx?pid=APOGEEGT
http://www.microplex.no/product.aspx?pid=AC23388
http://www.microplex.no/product.aspx?pid=AC41020MI
http://www.microplex.no/product.aspx?pid=K0100608
http://www.microplex.no/product.aspx?pid=MI18TM38ID
http://www.microplex.no/product.aspx?pid=MI14TM38ID
http://www.microplex.no/product.aspx?pid=AC32021
http://www.microplex.no/product.aspx?pid=AC31021
http://www.microplex.no/product.aspx?pid=AC34328
I was gonna place it all in this case:
http://www.microplex.no/product.aspx?pid=PCG70A
First of all, did i forget any components?
I should be enough to watercool graphic card and prosessor right?
Any of the components i should avoid, or replace?
Any tips would much appreciated
cheers.
cheers.
