NeverBackDown
AMD Enthusiast
Yeah totally underailed thread... OP got his answer. Don't think a flame war will help get him another answer.
So OP as we established. Your board won't work with SLI(unless there is a BIOS somewhere that adds support for it). So you can get the 980ti you want now, but if you plan on 4k you will need a new board if you want playable framerates as SLI would be the only solution atm. Good luck
