mrDMxtreme
ok so i got a gtx 580 matrix, BUT i wanna water cool the stupid thing , and there are no full cover blocks for it
SO i want to use a universal gpu block, but i have some questions regading the cooling of the rest of the card.
first heres a good pic of the card and its current cooling solution:
if you notice the only spot that the heat sink touches is the cpu itself, and the rest just gets the warm air flow from the fans after it passed through the heat sink. my question is if i use a universal water block and put fittings on it everything i think it will cover the memory chips on 'top' of the card (in respect to the pic ) i know about the little alimunium hs you can buy, but i think the water block+fittings+ hose might be in the way?
(for example)
what do you think? also if i do this i was planning on putting the fan shroud back on (some how) to get air flow for the rest of the components. is that over kill? or not enough or what? lol i don't know how much cooling the rest of the card needs since this current hs doesn't connect to anything but the gpu.
the long and short of it, i was think of replacing the aluminium hs with a universal waterblock.
any feed back is welcome, and thanks
(for example)
