Need a temperature monitoring program!
Philib
Hi there guys, are there any free temp monitoring programs that can log my CPU and GPU temps as I use my PC.
I did have the OC3d gadget but I cant seem to find it. If someone has a link that would be good.
Many thanks
i wrote a HWmonitor for OC3D, but there was not alot of downloads... so i took it off my server :(
i licensed the SDK from CPUID
writing the app is simple.... deciphering the sensor ICs, is the tricky bit ;)
I've always just used Realtemp for temp monitoring, simple and it works. Also, EVGA Precision has a bluetooth functionality where you can monitor your graphics and adjust settings in real time, so I can fiddle with my overclocks without ever leaving a game. Pretty cool stuff.
BTW will there be a midnightsmurf update today?
Try to keep things on topic, Rossi. If you have something to ask another member, either post it in their thread or PM them about it directly.
I use the All CPU Meter and GPU Meter from Addgaget. Theyre gadgets that stay on your desktop. The All CPU Meter has to be used with PC Meter to monitor your temps. If you can find an older version, thatll use Core Temp which I think is a little better and itll put the temp in your taskbar so you can see it without having to go to the desktop.
When overclocking and stress testing, I just use OCCT's monitoring features.
Was it the OC3d one? If it was I had it. After a new hardrive went in I have unfortunately lost it. Any chance you could get it over to me some how?
