mrDMxtreme
First let me tell you what I'm looking for, I need: some small and very portable aka thin and light weight. I was thinking between 11.6"-13.3" screens and around 3 pounds, max 4 pounds. Also the second most important thing is battery life, it's gotta last, the longer the better. Next requirement is it's gotta be cheap
lol I don't have a lot to spend on this (preferably under $500 but max $600, if I did it would be a lot easier. (btw i'm in canada, i'll link some stores at the bottom if you want to have a look at prices)
So I've been looking online for a little bit and let me tell you what I found: first I found the thinkpad x120e, next I saw the msi x370-205us, then i saw the Sony Y series, then i saw the HP dm1.
The msi is the most expensive, but I think it's got the best battery life, fastest apu and 13" screen, the others are 11.6", the HP dm1 is the cheapest but the thing is it's HP and I had bad experiences with HP.
So basically I'm confused. Help me out, I am willing to any other suggestions, or at least which of these u would spend ur money on.
And if there is only 2gb ram, add $25-30 to the price because I would open it up and add the 4gb that I want
Oh yea almost forgot what I need to be able to do on it
I need it to be fast enough to have like 2pdfs open and word and excel and internet, also would like it to play hd YouTube video.Its for university, as i just started computer software engineering
sites:
http://www.canadacomputers.com
http://www.newegg.ca (don't forget the .ca for the last 2, cuz i think there are us prices for .com)
http://www.futureshop.ca/en-ca/home.aspx
sites:
