oO_KoPiTe_Oo
I'm currently running a d-link pci network card. Yes I have 5 bars constantly but Another pc is
also on the same network running through wirless. This makes it rather fustrating for me when
gaming/streaming football and what not.
I really want to run a connection through an ethernet cable. The router used to be in my room and
a standard 3m yellow ethernet cable worked fine. I just moved house and I'm wanting to have the
same smooth connection but over a much longer distance. I'm wanting to order 25 to 30 metres of
cable but im not sure what type I should be looking at. I must admit im no good when it comes to
dealing with anything internet related. I used to think all ethernet cable was the same and there
wasn't any lower or higher quality cables. There must be a difference between a 30m ethernet cable
on ebay costing £4.00 and ones costing up to £100. I'm seeing Cat5, Cat6, UTP, STP, RJ45 and im
baffled, what does it all mean?
Sorry if i'm confusing people, i'll put the question's I want answered into much simpler terms...
Will this cable from ebay costing £4.00 work perfectly connecting a single pc to a router?
30m Ethernet cable Ebay Link
What do Cat5, Cat6, UTP, STP, RJ45 all mean?
Thankyou in advanced for answering my questions.
