EllieThePurpleFuzzy
Trouble is this motherboard is HUGE it makes my X79-UD3 look tiny so i guess it's a E-ATX?. it's height is fine it'll fit in going side ways but the motherboard is a limosuine and is quite very long.
i have a case budget of about 40-60 quid but this is for new and used, and i'd like a case with good ventalation as i'd likely want to use a non reference 7950. and a case with vents at the top and a one with the PSU at the bottom.
one idea i had was the thermaltake snow commander case but i dont know if that is big enough, just the idea came from a friend who has it and says it's absolutely massive.
(this is a build for a friend who has to use his lower end i3 laptop for now)
Build is this for anyone curious
Xeon X5650
8GB RAM
Non Reference 7950
2x 500GB HDD
Xeon X5650
8GB RAM
Non Reference 7950
2x 500GB HDD
