Nanoxia Deep Silence
MadMarc
The german brand Nanoxia brought out a new case that is as far is I can tell pretty much an exact copy of the fractal design define r3 or r4, only the front door is a bit different. Even things like the ModuVent have been copied. So it's essentially the same case, only worse and more expensive.
I have first seen this case on computerbase.de and now it's also available at a Swiss store.
What do you guys think of this?
http://www.nanoxia-world.com/
I think the way they've implemented the front bays looks good - you can get a H100 in there in push/pull. Plus the fact that you could have fans pulling air in from the front but internally bodes very well for a quiet case... It also looks to have 2 integrated fan controllers in the front as well.
