After 2 years with SFF cases im missing the space, so I bought a stacker 831 for my gaming rig and let the gf to use the Fragbox2 to watch movies
Here's the spec:
Q6600 G0 3.6Ghz 1.34v
P5k-E Wifi
4x1GB ballistix
XFX 8800GTX
HDA Xplosion7.1
150GB Raptor + 500GB WD AAKS+300GB maxtor
Corsair HX620
Cooling:
D-tek Fuzion with quad nozzle/pro mount
MCW60/D-TEK Fuzion (havent decide whch to use) with 8800gtx uni-sink
2x EK mosfet block
DD MPC NB block
DDC 3.2 18W with XSPC Res top
PA120.3 + 3x S-flex f fans
4x Thermaltake CL-0028 Ram cooler
Thermalright HR-05-SLI/IFX for SB
This is the case (sorry forgot to take a actual pic)
And I love the new DD fatboy barbs, looks amazing!
I have got the jigsaw delivered today so im finally start to mod my case
I cut the top section of the case and will be mounting the pa120.3 there. The cut out is a little shorter than the pa120.3 so I may need a grill for it to make it easy to remove when needed.
Both watercoolinguk and aqua-pc confirmed my order despatched so I should receive them tmr, will do more work this weekend and upload pics
Here's the spec:
P5k-E Wifi
4x1GB ballistix
XFX 8800GTX
HDA Xplosion7.1
Corsair HX620
Cooling:
2x EK mosfet block
DD MPC NB block
