My Upcoming Build "Dragon's Mist"
Excalabur50
Well-known member
G'day OC3D I ordered my parts today for my upcoming build "Dragon's Mist"
So with a bit of luck they should arrive next week
Case: Corsair 780T in white
CPU: Intel Devils Canyon I7 4790K
Motherboard: MSI Z97 Gaming 9 AC
Graphics: 2x MSI GTX 980 Gaming in SLI
Cooling: Corsair H105 with 4x Corsair Sp120 White Led QE in push pull
Memory: GSkill 16GB 2133 Ripjaws Z
Monitor: Asus ROG Swift 144Hz 2560x1440 1ms
Keyboard: Corsair K95 RGB
Already own and will be included
SSD: 2x Samsung 840 Evo's 250GB in Raid0
Power Supply: Corsair AX850
Cables: Corsair White Individually Braided Cables
Mouse: Corsair M65 in black will later be getting the RGB model but they won't be in country for awhile
And other sundry items listed in my sig
And I must say I'm really looking forward to building this rig and sharing with all my bud's here on OC3D! Feel free to comment!:D
Will post pic's later when I have everything
First Item has arrived
Ok the rest of my stuff less monitor
Cheers I'm getting excited about it all now:D
How are you going to be running the wires for the H105, I have just got a H105 myself and i was thinking about not using the Y-Header i was thinking about just plugin the fans into a fan hub i have just hope it will work like i'm hoping for.
I will either use the fan controller on the case or will wire it up to 12 volt with a fan speed reducer like Tom does not made up my mind yet
Good advice i try that with the X61 plugged it into the fan hub but it didn't work for me maybe it has something to do with the NZXT, i think i will end being more happier with the Corsair over the NZXT :D
Well slight disappointment today my supplier didn't have enough 2400 speed ram and didn't know when they could get more so I had to settle for 2133 :( but they shipped it today should be here Friday or Monday latest :)
Alright then my stuff arrived mostly today Aus Post have lost the monitor but have updated OP with some pics for now will add more later!!
Here are some pics of the actual build this first pic is of the replaced rear fan for an LED
Here is a pic of the board before adding anything
This one is with the ram and stock Cpu cooler as had a part missing for the H105
A shot of the ram looks great I must say
Here it is fitted in the case with the Corsair white cable attached
This is with the sexy 980 gaming editions fitted before cable attachment
A shot of the RGB M65 on the MM600
The RGB K95
Stock lighting
And the mouses stock lighting, guess I should have gotten rid of the crap at the side of the pad first huh oh well
So there we have it for now more later
The RGB K95
Stock lighting
Looking good dude, can't wait to see more looks like your build is turning out better than mine :D
That cover for the I/O and Audio section looks ugly in my opinion. Other than that your system is great. I hope that you get the missing part of the h105 soon!
