My Rig - Update Cosmos II
Running a third nvidia card dedicated to physx will not improve your (Edit: Vantage) score if you are already running nvidia cards for graphics.
wrong
i have my single 460 i added a 9800gtx and my score whent up
see attachments all settings were the same
Well, I didn't specify, but I was talking about Vantage not the Heaven benchmark. I'll edit my post to reflect that
yeah its cause of my mobo layout why i cant have the extra card in, just running heaven now, will post results up soon
edit: here is the results with it oc at 880/1760/2100
loool
take the CPU to stock and run it,cos that i7 at 4ghz is crazy
not that crazy
just my benchmark settings, got ram at 2000mhz CL8 as well
just ran 3d mark vantage again and got
3dmark score p34358
gpu score 30038
cpu score 60434
link below shows it
3d mark
best score so far
loads better than my 8.5k gtx 260 lol
will clock it down now and try heaven
jaysus you min took a hit lol
get it back to 4ghx man,they are some good scores.
are you gna OC the cards more
EDIT can you run it 1920*1080 or is that your max res
thanks
my highest res is at 1920*1200 will try it at that in extreme settings
can you not run a benchmark at 1920*1200 cause everytime i try to it resets to 1280*1024
i can run heaven at 1920*1080 yes,its there by default.just change it if its not there
i dont use vantage fella
are you using the 258 drivers or the BETA
its heaven im trying to run at the res, i set it before i go into it and automatically goes down to default then i try changing while running it does the same still
and yep using the 258 drivers
Just an update, bought the NZXT Sleeced LED Kit white 2m and quite impressed with it very easy to fit in anywhere, only annoying thing was a cable to a molex connection had come out and wasn't going to return it to ccl just for that so i just fixed it myself and works fine now for the pics
the box
what comes in the box
now it fixed in and lighting
Got to say am very impressed with them, just got to wait for NZXT to release a side windowed panel now
