BileMonkey
Hi guys, have finally finished my first new 'proper' rig in about 5 years. It's been up and running a week or two now but I'd been awaiting a few extra parts to finish the build off. For the last couple of years I've been a bit nomadic and so had been gaming on an MSI Laptop (recommended on this site), which had served me pretty well to be honest, but it was starting to show its age with the latest games and, well, it's not "your" rig unless you build it from scratch. Anyway, I've finally settled down and it felt about time to build something a bit shiny shiny. I had a reasonable budget but as always, you keep finding a way to justify something that little bit more expensive and in the end I had to draw a line in the sand. Hence the i5 in a build where you may expect an i7. I'm getting married in October and if I'd spent any more money on this (let alone time - it took weeks to plan exactly what I wanted) I think the missus would have made me a eunuch.
Upon first build I'd been a bit pikey with case fans and had recycled the stock cooler fans and some old fans from the misssus' build in to case. The problem was that some of the old fans were super noisy and I had to run the case's integrated controller at it's lowest setting. So, I swapped all the case fans bar the 200mm side panel fan and the two 200mm top fans for Corsair AF140 quiet editions. I can now run at the mid-setting near enough silent and the high-setting is perfectly tolerable. Well worth the upgrade.
Other than gaming, the rig is mainly used for Photoshop and video editing. An i7 would have been nice for video editing, but with DaVinci Resolve and Prem. Pro being well GPU accelerated these days I can't say as I've ever 'missed' the extra hyper-threading.
Anyway, this is my new baby :wub:
The specs:
CPU: Intel i5 4670K @ 4.2GHz
CPU COOLER: NZXT Kraken X60, fans swapped out to 140mm Akasa Vipers as stock fans far too noisy.
RAM:32GB Corsair Dominator Plat. 1833MHz @ 9-9-9-27-175
MOBO: MSI Z87 GD65
GPU: 2x nVidia GTX780 in SLI
HDD1: Crucial M500 480GB
HDD2:3 x 1TB Seagate Barracuda in matrix RAID (1TB RAID0 and 1.2TB RAID5)
Case: NZXT Phantom 630
Cooling: 6xAF140quiets and 3x200mm NZXTs (1 side-panel, 2 top)
PSU: Corsair AX680
SCREEN1: Dell 2713HM
SCREEN2: Dell 2407WFP
KBD: MS Natural (not very "gaming" but I've used MS Naturals for the last 15 years and wouldn't use anything else now, they're just so comfy to type on).
MOUSE: RAT 7
GAMEPADS: Razer Nostromo and Wired XBox 360 Controller
Pics:
The specs:
MOBO: MSI Z87 GD65
PSU: Corsair AX680
MOUSE: RAT 7
Pics:
