My NODE 804 Build
almighty15
Moved to this amazing case last week and while the build isn't finished ( It's around 80% complete ) it's already looking might fine.
Although as Tom pointed out in the review, an extra inch in height, width and depth would of made the case that much better.
De-lidded 3770k at 5Ghz ( Passed Intel Burn Test and everything I've thrown at it )
8Gb Avexir 2133Mhz RAM
ASUS P8Z77-M Pro
Sapphire R290 at 1250Mhz core
Super flower 750w PSU
2x 2.5" Mechanical HDD's in RAID 0 for Steam and Origin.
Got to add a second 240mm radiator in the motherboard compartment, change the block and order a matching set of 12x blue LED fans and she'll be complete :cool:
ooo thats pretty, very nicely done
You going to get some black pci back plates or are they in the theme with your fans?
is that ram running at 2133 whilst the cpu is at 5 ghz, if so that is impressive. what is the voltage you are running?
Tidy build for such a small case
