I have been lurking on this site for quite a while and hate seeing the message on every page that I haven't yet posted on OC3C :nono:.. So consider this my "Hello OC3D" thread.
I'm putting a phase change unit in the bottom of a Lian Li V2000B case and the top will be setup for a 120mm X 3 radiator for a water loop for gpu or gpu/nb. The top is already cut out for the radiator and has a Danger Den grill on it. I probably wont' install the water loop myself, but will leave that to whoever ends up with it; I probably will have a blue bay res installed to go along with the blue/black theme of the whole unit.
I have a Sunbeam fan controlller and am considering a Crystalfontz or Matrix Orbital blue lcd. I also have to consider how to integrate the phase unit with the pc system, ideally a controller will be used to make it a "one button push" to start the phase unit, then power on the pc when correct temp is reached. That will either require a 3rd party controller or a controller out of a Vapochill/Prommy. (this is one of the things still to be decided)
Anyway.... I'll update this as work progresses, here are some pics of the case as it looks now.
BTW... I plan to replace the side window, I don't like the fan holes that were cut into it when I got it. Does anyone know a good place to order plexi or acrylic panels for side windows? I haven't decided if I should use clear, or blue tint for the window... any suggestions are welcome.:coocoo::coocoo:
