Shakal
What's up OC3D. Last night after 1 month of trying to make my 1st water cooled rig perfect i finally finished it. It's been together and apart at least 3 times but now i am DONE! It's time to actually use it
Down the road i plan on adding another 7970 but for now there is no need as it simply maxes out anything i throw at it.
Here is a full blown spec list:
Case - Corsair 650D Powder Coated Orange with few mods in order to fit 360 and 240Rad.
Motherboard - Asus Sabertooth x79
CPU - Intel Core i7 3930k
GPU - ATI Radeon 7970HD
PSU: XFX PRO850W XXX
RAM: Corsair Vengeance 16GB @1600mhZ
HDD: ocZ Vertex 3 120GB and Western Digital 1TB Caviar Black
Asus DVD Drive
All Black Cable Sleeving
Water Cooling:
XSPC Raystorm CPU water Block
Swiftech Komodo Full VGA Waterblock
Danger Den Reservoir
Swiftech MCP655 Variable Speed Pump with full Bitspower mod kit
2x Delta 120x25mm @ 4000RPM
Black Ice GT 240MM Radiator
XSPC RX360Radiator
3 x Scythe Ultra Kaze Fans
A mix of Bitspower and XSPC Compression fittings
Black XSPC Tubing 1/2ID and 3/4OD
White Lighting including NZXT Whiter Sleeved LED Strip and a White Cold Cathode.
Right now i'm really happy with the system i had to do a lot of revisions as i was not happy with the temps. Right now i'm sitting at stable 4.6GHz @1.34vcore on the processor @ about 30-34 idle temps and about 55 full load. The gpu now stays at cool 33 idle and 40-44 full load overclocked at 1.2v core clock @1125mhz memory clock @1575
Here is a link to a short youtube video as well as some pics. I kind of wish i knew how to do some expert photography to really show it off but i think these will suffice. Please let me know what you think
http://www.youtube.com/watch?v=t5RIbxeWYuA&feature=plcp
The 3930k at 5ghz was stable on prime 95 for 5 hours with max temps around 85 on the hottest core. But i didn't want to continue as i will never run that cpu at those voltage. Right now i'm running 100% stable at 1.35vcore and 4.6ghz
some screen shots
http://www.3dmark.com/3dm11/4350102
Asus DVD Drive
Water Cooling:
XSPC RX360Radiator
some screen shots
