BileMonkey
Looks awesome. The red PSU cables are class, and I like that you've re-coloured the GTX logos. Really neat, too. It's a really smart looking rig.
The more I see of them the more I like the Corsair 350D. Build looks awesome and has made me seriously consider an matx build when it comes upgrade time.
that looks stunning i like what you did with the gpu with the smoked window door on you wouldn't notice it![]()
I have the M6 Gene aswell. Are you running adaptive voltage on the Vcore?
I was a little confused when setting mine up. Ended up setting 1.05V as the base then just added the extra little offset I needed to get to the same voltage as what I used when setting manual Vcore for overclock stability testing...
You're right, you don't see it at all at night, here's a (grainy) pic. Oh and I added a nice new 120hz/3D monitor today too - happened to be black and red![]()
I'm REALLY no expert when it comes to overclocking, so I used that '4 Way Tuning" thing that does your fans etc. It goes off and does its thing and set mine at 4.6Ghz at about 1.26v or so - memory at 1866 via XMP - seems stable enough though OCCT does make it get very hot (~88c !).
Loving the rig.. would like to see the results of this glass pen.. as i've got a 780 in my black/red rig and was looking for ways to mod the colour.
did you get the back plate straight from EVGA?
oh and it had a red cap if that helps.
