My first Build LC 600t
Thats an idea. Would just have to find a place for the pump. Would that screw right into the 200 fan holes or would i have to mod a little?
the rad shouf fit rieght into the rad and notmaly (or lets say in the case of phobia rad#s you shod get the right screws so you can bolt the case trought the fan direct nto the radiator.
I dont think tht you have to mod enything in the case... but the pump coud be a bit compicated. you cod put the pump betwenn teh drive cage and the radiator (buts that is perhaps not the best way for the airflow). i had a pump mountet upside down at the floor of the 5'25 bays (but thats the same problem witch teh air flow).
i dont know if you find som space in the 5'25 bays or in the roof of the case but i think that those last ideas require some modding.
I woud personaly fit the pump between te new poaition of the drive cage and the radiator.
To the question if you wat to use a double 120 or an 200 rad i woud go with a 200, because all atvanteges are on the side of the 200, you get fare more surfice area with a 200, there is no modding required and you dont run in any problems that the fans come to close to your mainboard.
But dont forget to mesure al the parts and make sure that it woud fir before you get the parts because i only know the case from some pictures and have seen som mods.
thats a build log of an 650d wat coms in my obbinion raly close to an 600 in the proportions of the front part.
dont want to say that i like the build log (from the 650d) but it shoud give an impression what i want so say
http://www.overclock.net/t/969234/close-combat-a-corsair-650d-water-cooled-build
