Hi guys, a while back i decided to build my new PC, this was a budget build so I had a cap of £650 for the whole build.every part listed below was won in an ebay auction to outbid must users i would have to stay up very late till 4 am sometimes to outbid them i get the purchase after weeks / months of doing this I finally had all the part and was ready to build my new rig
below are all the parts, out of all the parts I did have to buy one item new and cut to size and that was the Color Perspex Acrylic Sheet Plastic Material Panel Cut to Size ( Translucent Black ) witch I used as a top dust cover it works very well
hope you like it if you have any question please feel free to comment below thanks #
MSI B85M-P33 - Socket 1150 Motherboard - Micro ATX
MSI GeForce GTX 670 (2048 M (N670GTXPE2GD5/OC) Graphics Card
Seasonic S12G-650 650W 80+ Gold Certified PSU
be quiet! Pure Rock BK009 CPU Cooler with 120mm Fan
Corsair Obsidian Series 350D Performance Micro ATX Case with Windowed side panel
Intel Core i5 4670K - 3.4 GHz Quad-Core (BX80646I54670K) Processor ( O/C 4.2 )
Corsair Vengeance Blue 8GB 2X4GB Dual Channel DDR3 1600MHz PC3-12800 LP Desktop
Corsair Air Series AF120 LED Blue Quiet Edition High Airflow 120mm Fan Dual Fans
OS - Team Ultra-L5 SSD 120GB
Storage Drives - WD Green 4TB, WD Green 3TB ( I wish they where the blue or black ones, but this is a budget build )
Extra
4 Pin ATX EPS 30cm PSU Extension Cable Black Blue Sleeved Power Supply
6 Pin Black Blue 34cm PCIE PSU Extension Cable Sleeved Power Supply x2
24 Pin ATX PSU 34cm Extension Cable Black Blue Sleeved Power Supply
Molex to 3 x 3 pin Fan Adapter 7v Black Sleeved Extension Power Cable Modding
Round Sata 3 Cable - Right Angle Black - 45cm x3
25CM Blue LED Flexible PC Computer Case Adhesive Strip
Square Rubber Feet Black Self Adhesive
Extra
