My AciD CooleR
mundivalur
System specs are:
Case: Haf-X with a big window mod
Cpu: i7 2700k@5.0ghz
Ram: 2x4gb Geil Evo Corsa 2133mhz mod-ed with acid green acrylic
Motherb: Gigabyte P67A-UD7-B3
Gpu: 2x Evga HydroCopper 480 GTX
SSD: Corsair Force 3 120gb
Psu: Cooler Master 850w
WC: Raystorm cpu block,Phobya 250mm res,Xspc RX360,Specialtech fittings :p,Alphacool TPP644 Laing D4 and Primochill PrimoFlex Pro LRT 1/2" ID - 3/4" OD UV Green, rad and res are external
Other: My 100cm custom UV Led strip:cool:,My sleeving/braiding the 24pin is still paracord waiting for material to finish ! Made a little mod on the SLI bridge using the acid acrylic and more acrylic at the 5.25 bay !
Finally starting a other color build ! coming soon :cool:
That is superb, you've done a great job!
I'm not a huge fan of green but I love this build. Have you got anymore pictures ?
Thanks ,it has taken a long time to get the right lighting and all small parts,when you have to order everything from EU or US it takes allot of time learning what works, but i have learned extremely much and still learning haha
I have to take some more photos later :D
Im not sure about the mismatched braid or the thing on the window. But I do like it a lot fella. Im pretty sure everyone is used to my picky-ness by now :D
The 8pin and 24pin cables are still paracord :) waiting for High Density braid/sleeve to finish it ,then i say stop to this build oo dam now i remember i got a 420mm rad some where in the mail ! may need to put it in the front haha
