The G45 is the basic z77 overclocker which will see you into the mid 4GHz range. The GD55 has better transistors and the GD65 has more of the better transistors. The difference that makes is not worth more than 100-300MHz. I had a GD55 and upgraded to a GD65 and saw precisely zero improvement in my overclock.
There are some other differences such as the GD65 having 2 more 6gb SATA connections and a dual bios.
The g45 doesn't support lucid virtu if you are looking at that. The 55 and 65 have voltage check points if you want those.
They all have the same memory, USB 3 and PCIE3 support and are generally excellent quality boards with frankly very little to split them apart as far as most users are concerned.
The g45 is just fine. I would recommend the 55 on balance.
Dude I just looked at the price difference between the 2 boards.
$10..... Really dude 10 bucks? :lol:
well at least here in Toronto![]()
That's what I said, it will get a mid 4GHz overclock! It's largely chip dependent after that anyway depending on how many volts you want to put through your CPU.O rly?
I had my 2500k on a MSI z77a g43 at 4.5ghz stable with a H60.
but... The g43 did not let me manually change cpu volts.. I'm not sure if its the same crap with the g45
Hi guys
I know i definately want the z77a board but i dont know if its worth gettin the gd55 over the g45... What are the differences and is the 55 worth the extra 30 quid?
Thanks in advance
Devin
Mate go with the GD65 its only a bit more expensive. Check out ebuyer i think its cheaper there.
