Hello guys, please i need a help.
MSI Live Update 6 always says my Intel ME driver is outdated.
I installed the 7.1.52.1176 several times, and the Intel installer driver window always says: Update Successful. But Live Update still says my version is 7.1.50.1172. I installed the latest version (2.1) of Treexy Driver Fusion, and it says that i have another drivers outdated, but i must to purchase the Premium version to download them.
Do you think that is safe to install motherboad drivers from there ?
I already contacted the MSI support, and the answer was: we don't recommend to install drivers from third party software.
I did a google search trying to find any information and/or download links, but i had no success.
I had some issues last week (black screen and computer does not started up and played 3 bips, 1 long and 2 shorts), so that's why i'm searching for the latest mobo drivers, i did nothing to fix it, but now my computer is working fine. (I runned the BIOS memory check and it says memory is OK)
I tried to attach a print screen with the Treexy Driver Fusion Window showing the drivers that it says is outdated, but i may NOT post attachments here.
The drivers list is:
Mobo resources: Update to 9.0.1000.0 (version installed: 6.1.7601.17514)
Timer of high precision events: Update to 7.0.1.1011 (version installed: 6.1.7601.17514 - same as above)
Intel Menagement Engine Interface: Update to 9.5.14.1724 (version installed: 7.1.21.1134)
PCI bus: Update to 13.251.3.0 (version installed: 6.1.7601.17514 - same as above)
All these driver has a small 3 red bars icon on its side
and, Intel 6 Series/C200 Series Chipset Family SMBus Controller - 1C22: Update to 9.2.0.1035 (version 9.2.0.1011 installed) this one is only with 2 orange bars on its side
Please help me about what should i do.
Thanks in advance.
My rig:
Intel Core I5-2500K w/Cooler Master V4 GTS (2 years of use)
16 GB RAM GSkill RipjawsX (4 x F3-10666CL9D-4GBXL) (2 years of use)
PSU Corsair TX650 (1 year of use)
EVGA GeForce GTX 770 02G-P4-2774-KR (1 month of use)
Seagate ST2000DM001 (1 year of use)
Mobo BIOS Version 1.J0
Windows 7 SP1 X64
I guess i need to update the MOBO BIOS.
The BIOS Version 1.J0 is the latest that can be updated using the MSI Live Update, but i found a newer version (Version 4.3: Description - Enhanced PCI-E display card performance.
- Improved memory compatibility) on MSI mobo BIOS download page: http://www.msi.com/support/mb/P67AGD55_B3.html#down-bios
I tried to update (flash) the BIOS using a SanDisk Cruzer Blade 4GB USB Flash Drive Model SDCZ50-004G but i had no success. Windows does no recognize it as a pen drive, but as a hard disk. When i double click the E7681v43.exe file a message appears saying: The file can only be excuted in USB pen drive!
Please copy the file to you USB pen drive then run the file again.
Any tip about how to fix it or should i try another pen drive brand/model ?
Thanks in advance.
My rig:
Windows 7 SP1 X64
