MSi GTX 580 Twin Frozr II/OC
Ya93sin
Today seems to be an overclocking day.
So I've set my sights on the GPU, mainly I want to be recording most games with Fraps at very nice framerates. (Some games I can do this, others are a bit dodgy).
So from the get-go my card is OC'd at:
Core Voltage 1025mV
Core Clock 800MHz
Shader Clock 1600MHz
Memory Clock 2048MHz
Idle Temperatures 28-30 deg.C
Drivers: 275.33
BIOS: 70.10.20.00.01
Peformance atm:
3dMark Vantage: 23069 @ "Performance" Preset
3dMark 11: P6117, 6327 for the Graphics Score @ Default Settings
Should I just go for the max without adjusting the Core Voltage?
What kind of ballpark figures should I be aiming at?
Thanks
Have it running at the following settings atm:
Core Voltage 1025mV
Core Clock 900MHz
Shader Clock 1800MHz
Memory Clock 2100MHz
Max Temp: 57deg C (having run MSI Kombustor/KMark Extreme
Well I'm not going to raise the Voltages, surely it shouldn't fail otherwise?
Quick update (now running OCCT to check):
Core 900
Shader 1800
Memory 2250 (4500 effective)
Max temp reached during a 10minute run (the longer test I'll do later): 60 deg C
0 errors (i.e. artifacts)
From the OCCT thing, the FPS is hgiher, both average and max, from before memory OC (from 2100MHz) the max was 250fps, from after memory OC (at 2250) the max is 380.
Running games is a different matter, crashed in Crysis2 Benchmark at both 2100/2250MHz Memory clocks.
Alright, because I want to game this evening, I've left settings at the following:
Core 850MHz
Shader 1700MHz
Memory 2100MHz
Anything above these settings makes Crysis2 want to crash
I suppose a little voltage might help, but then that defeats the purpose of squeezing the maximum performance from the card at default volts.
Updated: Now stable at 1.1V:
900MHz core
1800MHz shader
4400MHz memory
I'll check other things, but here is the Mafia II improvement:
This:
To this:
I'll post the rest in my Project Log.
In general gameplay, from 80fps-ish, I've got about 110fps-ish.
